2015 D4-300 Automatic Tranmission Service
JeffreyAC77
2015 R31-CB (LE)
Lake Union, Washington
R-31 CB
FMLT3106E415
State of Mind
Does anyone have a link (video presentation) or the written procedure to do this service?
thanks in advance.
Thank you. Can you show/tell me where to drain the ATF and refill it?
Remove the dipstick and put a small diameter plastic tube into the opening. Feed it down to the bottom of the gear housing. Using an oil pump extract the oil out of the transmission. Remove the oil filter cover, and filter. Fill the transmission where the filter is and check the level with the dipstick. When the oil level is showing on the full mark install the filter per Thread instructions that I posted. When you are finished start the engine and shift Fwd and Reverse. Shut down the engine and check the oil level. Do not over fill.
https://www.googleadservices.com/pagead ... QMA&adurl=
