ohioan55
- Aug 25, 2015
- R-23 (Outboard)
- FMLT2314C424
- Jersey Girl
I'm seeking wisdom from your technical gurus. Our r21ec developed a whine last year. The whine is only present between 1100 to 1900 engine RPM, and only in forward gear. It will abate when throwing on rudder (sometimes). First thoughts was the cutlass bearing. First, I checked the engine alignment (twice). Looked to be in tolerance, so I towed it to the local yard (also the Volvo Penta folks in the area). They swapped out the cutlass bearing, but the whine is still present. They also did an engine alignment after the boat had been back in the water a few days. The tech who was there said it was the transmission, so I pulled the boat again and returned it to the yard.
The yard pulled the transmission, did not see an issue, consulted VP corporate. They recommended replacing the harmonic dampener. After replacing the part and reinstalling, the whine was still present (no change). So the transmission was again removed and set off site to be rebuilt. The unit came back, was reinstalled, and the whine was still there. The transmission was pulled for a 4th time and sent to the offsite rebuild facility, where they replaced all bearings. The unit was returned, re-installed, and upon testing the whine was still present. Every part from the back of the engine to the prop has been removed, inspected and/or replaced, and reinstalled multiple times. After discussing the situation with the yard, we decided to just run it and see what happens. Do the factory folks have any ideas we can check, prior to me ordering an R23?
