2015 R31-CB Cockpit Circuit Breakers
JeffreyAC77
2015 R31-CB (LE)
Lake Union, Washington
R-31 CB
FMLT3106E415
State of Mind
I am having a problem with my 120v outlets not working. One of the circuit breakers (behind the seat in the cockpit) is not lit properly (the left one). The other circuit breaker has the proper "on" light illuminated. What is the part # for replacement of the unit and is it a difficult fix?
Not sure where the AC Breakers are on the 2015 R31, on the 2022 R31 they are on the left as you enter the cave.
Once you disconnect shore power, turn off the house battery and the inverter, and then check the back of the circuit breaker (CB) and the line bus for voltage replacement of the CB should be fairly simple. There may be a mess of conductors in the way (there was a mess of conductors on my boat), I disconnected one at a time and straightened them out, just to simplify future work.
We have the same year R-31. If you are referring to breakers behind the aft cockpit bench seat, those are ELCI breakers. One is for each of your shore power inlets.
One of the breakers behind our cockpit seat is lit properly (the right one), the other not (the left one).
I believe the Air Conditioning breaker is the one that is lit.
What is the remedy for the one that is not lit. We have a single power cord going to splitter to connect to the plugs on the boat. It may be a faulty cord - if so, what is the difference between cords that are less than $100 and those that are more than $750. thanks.
