2015 R31-CB WATER PRESSURE PROBLEM
JeffreyAC77
2015 R31-CB (LE)
Lake Union, Washington
R-31 CB
FMLT3106E415
State of Mind
Since cleaning our fresh water tank, we now have little to no pressure in our galley or head sinks. The cockpit sink works fine. Two questions:
1 - Where does the line go from the galley sink?
2 - Where does the line go from the head sink?
Thanks in advance.
I would recommend first to remove the screen filter on the bottom of the galley and head faucet to see if they are clogged.
Have already done that. I assume there is a blockage somewhere down the line.
Thanks in advance.
I had the same problem this season. First I cleaned the screen filter on the fresh water pump which was completely clogged up. When this didn’t solve the problem I ended up taking the galley faucet out. Turned out to be the flexible hose that was clogged. Also take the head off the end of the flexible hose and make sure that this is free of debris. Next I took out the bathroom faucet and found that the hot and cold water pipes have screens on them. These were completely clogged as well. The faucet developed a leak where the pipes enter the handle portion of the faucet. My Ranger is a 2013 so instead of replacing the leaky hose I decided to replace the faucet. I can give you that link if you’re interested. Good luck!, not a fun job, I have the black and blues and nicks and scrapes to prove it.
Thanks for you offer. I have since cleaned the various screens and once again have good water pressure.
