2016 29 tug raw water strainer question
RMG001
Had a slow leak from the cover. Adjusting tension on the threaded cap did not help. The O ring is still intact, but a little stiff. Does anyone know where to get a replacement? Too big for local hardware stores. Too big for West Marine. Thanks ahead of time Rob
I’d suggest calling Ranger Tugs parts department. Either they’ll have it or steer you in the right direction. Also you can check with Fisheries Supply in Seattle.
Jim
Mr. Rob, if you can't get from Rangers supply dept. or marine supply. My I suggest you try the company that built the raw water strainer! Manufacture should be listed on it or get the information from Fluid Motions. Next I would try a industrial supply outlet in your area or you could always make your own with a O-ring splicing kit available from numerous vendors like ALLORINGS.COM.
If you can get the correct size of the o-ring usually with a little research you will be able to locate a supply source. Good luck, Bob
The raw water strainer for the Head, wash down, and air unit is made by Marine Hardware the part number for the sealing gasket kit number is SEA3GASKETS for the raw water strainer TOP VIEW MULTI-PORT SEA STRAINER - Self-Cleaning SEASMP-NPT-DOME.
