2016 RT 25sc doesn't reach full RPM anymore
chapman7132
C-26
FMLR2526A616
Scarlot
Since I have had the boat, full throttle RPM has been 3000 RPM. Not that I run it at full throttle very much, but occasionally short bursts. Anyway, in the past few months I have noticed max RPM is down to 2850 or 2900 if I am lucky. Anyone know of possible reasons why this happened? How I should approach this diagnosis? I have just changed the primary fuel/water separator filter which didn't make a difference.
Thanks in advance for any suggestions or pointers.
Randy
Dirty bottom
Loaded boat with gear.
Pretty common.
I guess I should have also added that the boat is pretty clean. Fresh bottom paint in May. And this problem occurs with the boat loaded or unloaded. RPM not impacted by the weight of the people and gear on the boat.
Here are common suggestions for lower Rpm of the D3 150 hp
When the boat was launched in May the engine turned 3000 +50 rpm ?
If yes
Bottom is dirty ( doesn’t take much slime to load the engine)
Prop is fouled ?
Trim tabs extending ?
Air filter element clean?
When you changed the primary filter was it dirty ? If yes did you replace secondary filter?
Do you know what your max boost pressure is at WOT when the engine is turning 3000rpm? Has boost pressure changed ?
Is the boat equipped for cruising? If the boat is light with no gear and 1/2 tank of fuel and 1/2 tank water 2 passengers you should see 3050 to 3100 with factory prop. When loaded full fuel, full water , equipped to cruise, 2 passengers 3000 rpm with a clean bottom. Add 2 more passengers and it would be normal to loose 100 rpm. The D3 Volvos are 2.4L engines good motors but it takes all they have to push a R25 and maintain recommended rpm. Any additional load from bottom slime, extra gear, additional passengers, head winds and waves. One or more of theses could cause a drop in max recommended rpm. My money is on a slimy bottom. 3 to 4 months in the water is plenty of time to have a freshly painted bottom to have some growth.
If the engine is running ok, normal temperature, check your fuel burn numbers. Compare the numbers to what you were getting when the engine turned full rpm. Compare your 2100 rpm or what ever rpm you normally run at fuel burn numbers. If you see a slight change in fuel burn this would also be an indication it is taking more power to push the boat.
Does your engine have a secondary fuel filter?
If so, try changing it.
