2016 Volvo D3 - 150hp engine anode locations?
Aadudley
C-26
FMLR2506F516
True Blue
-10 degrees in Ohio so naturally I'm thinking forward. I've looked all through my volvo manual and cannot find any information on whether or not it has engine anodes and if so where they are located on the engine.
Any and all help appreciated
Al
I don't think you find the location of the anode(s) in the manual because it is my understanding there are none in the Volvo D-3. That is one reason it is critical you use the appropriate antifreeze to run through the block. If anyone else has a different response, I would appreciate hearing it.
I have a 2016 D3 220 hp and there is no anode installed. I assume this is true for the D3 150.
Thanks everyone. I suspected that to be the case and now I understand the coolant requirement.
