2017 RT29 electrical problem
1Mainer50
C-30 S
FMLT2941C717
Saoirse
On boarding my 2017 RT29C (after 1 week) I saw that there was no power to the house circuit (AC Main 1), even while plugged in to the slip power. My power cable connection confirmed that there was power getting to the boat. No power was going to the Garmin and the refrigerators were all warm. The engine started as usual but I turned it off.
At the main panel I turned on the AC 1 and 2 Main switches. The AC Main 1 switch green light did not illuminate but the AC Main 2 switch did. AC panel 1 (microwave and three outlets) were all green. The second panel (accessory, oven cooktop, icemaker) would not light up, and the third panel (AC/heat) switches were all green.
There are three small lights set upper left of the genset switch, one labeled “green power available’, and two others labeled 1 and 2. The green power light was off, #1 was red, and #2 was green.
The analog ”needle” gauges show DC at 11.8 v for the house circuit and 12.5 for the heat/air. The AC showed 120v for each circuit.
I turned the generator on and engaged it. The AC Main 1 switch did not illuminate but all the switches at both panels (micowave, etc) did. The AC 2 Main and panel lights were all green. The inverter indicated the batteries were charging.
Switching the house and engine batteries parallel switch from off to on had no visible effect.
All systems were working fine a week ago. Any thoughts on what I should be looking for to repair this?
Well, it sounds like your batteries are not getting charged, hence no power going to charger. You may have power to your cord, but if the ELCI tripped then you won't have power to the panel. Locate your ELCI and check to make sure it is engaged. Then we can troubleshoot from there.
