2018 R23 Bow Thruster
Gramps
Cory 19 Angler
Stored indoors over the winter, but on first run of the summer yesterday my bow thruster did not respond. I’m afraid I have forgotten a switch or need to reset a circuit breaker but I don’t remember where either is located. Any ideas?
There is a breaker switch that must be turned on to get power to the thruster. On the 21 the breaker is below the captain chair not sure about the 23 but it should be fairly easy to track down. Also remember you have to push BOTH ON BUTTONS on the toggle at the same time to get power to the thruster. Hope this helps.
Thanks. Will try to locate. Think there is only one on button on the 23 though.
Did you look in the port cockpit storage locker for a circuit breaker/switch for the thruster? That is where it is on the 27OB.
My 2018 RT 23 has the thruster circuit breaker in the starboard compartment .
Is the bow thruster battery switch in the starboard cockpit storage locker turned to the "On" position?
There is a little push button beside the bow thruster control. Push that to turn it on. It should have a little led light that will glow red when on.
