2020 29S propane stove priming
DGHarting
C-30 S
FMLT29121920
Dress Blue
How do i prime the propane stove on my 2020 29S? I tried resetting safety valve on the tank but it was not tripped. See photos for my system.
When i push valve button it cycles through the lights and i hear the solenoid click.
The valve light needs to be on for the propane to flow. If the light is on check to see if you've got 12 volts at the wire connections going out to the solenoid. If you have the 12 volts and you still don't have propane then you can temporarily bypass your propane valve to prove that the valve is bad. See my thread "Propane 12vdc shutoff valve"
Are you sure there is Gas in the tank? I won't say why I ask that question.
I hear the solenoid click so I suspect t there is power, but I'll try your suggestion. I read another post about a safety shutoff on the tank itself but it doesn't seem to be tripped.
If you can hear the solenoid click you know the electrical part of the circuit is fine. So that just leaves mechanical issues of propane. Did you switch tanks?
