philbyrd
- Oct 29, 2019
- C-24 C
- 2021 R-25 OB SuperByrd
I am having a problem keeping AC running on my new boat. And, it’s been hot in Baltimore like everywhere else. I use my boat as my condo in the water, and work from home from the boat many days , so AC is crucial.
First issue is coming to the boat when AC had been off. Per my thermometer on the galley table, boat can be over 100 inside even with covers on and curtains drawn. I leave the cockpit cover on along with the optional sun shade extension. Seems to me the system is not capable of cooling to a reasonable temp in a reasonable time starting there, and it takes several hours to get it habitable. I start it and go to the pool, take a walk, etc. But, per below, I can’t now count on it to stay on.
I leave the boat on the dehumidifier setting when I leave. Temp when I open up is still up there (mid to upper 80s) but low humidity and the AC gets right to work. I was ok with this.
Current problem is system consistently shuts down showing E1 code. First time this happened on a repeat basis the raw water filter needed cleaning and I check it all the time now. Despite clean filter and flushing the lines, and a strong output flow, still have the problem.
When I first got the boat, this happened rarely, but did happen. Now, it may go a few hours but almost always is off in the am when I overnight and have to use AC due to brutal humidity leading to some very poor sleep. It is now always off when I return to the boat when set on dehumidifier setting. Which means I face problem number 1 all the time, and can’t count on the AC for my work day.
The AC pump gets very hot, and while that is likely normal I am wondering if it is failing, or some component in the system is failing. Seems to me the pump overheats and unit turns off due to no flow.
Please comment on the AC capacity and the R1 problem. I have asked the dealer but have not heard back yet, and I suspect they will seek factory input in any event.
My boat has the lithium option with soft start AC, but all these issues are on shore power. I suspect they would persist despite the power source.
Thanks for you attention to this.
