2021 R27
Barco
HONU
Hi,
I have a few questions regarding my recently acquired 2021 Ranger Tug R27.
1. Are the cabinets surfaces finished/treated at the factory, if so what material/product was used? Also, if the cabinets are not treated at the factory then what product is recommended to treat and protect the cabinets from stains?
2. The propane storage/distribution pressure regulator is loose, therefore should my next step be to repair or replace the pressure regulator?
Thanks, Louis
I am only going to answer #1 as I don't know #2. My 2022 R27-OB only had a finished applied to the interior of the toilet. It was some type of oil base waterproof product (based on the smell) due to it being a wet area. I think I knew the name but can't remember now. The rest of the boat had little if any treatment/coating. I know this because most of it was still covered with a light coating of sawdust from factory sanding. I was OK with this as I wanted to be sure I knew what the treatment would be. In my opinion the only thing to use on teak wood is teak cleaner followed by either teak oil or teak sealant. My preference is teak oil. It does require more maintenance but the look and protection when done properly is hard to beat. I don't recommend any type of "furniture" product/spray/cleaner. Once again...just my opinion...I'm sure there will be others
Regarding the propane pressure regulator, I had to replace the one on my 2021 RT27 after only one year. In my case, there was a faint smell of propane in the storage locker that wouldn’t go away with any amount of fitting retightening. A soapy water bubble test eventually revealed a small leak around the regulator vent.
