2021 R29 CB LE Transducer Location???
NoWorries
R-29 CB
No Worries
Please tell me where I may find the transducer in my 2021 R29 CB LE. I do not get ANY readings for depth on my Garmin display. It was intermittent at best just prior to its failure to report depth.
It is by your shower pump box. Pull up the removable floor in front of the head door and look to the outboard side of your shower pump box. It most likely ran out of fluid or it leaked fluid out of the cup around the base. If that is the case then you will need to reglue the cup base back down to the bottom of the hull.
Please let me know if you need anymore help.
Jared, Thank you so much for your reply. I'll circle back with my findings and corrective action / results soon. Carl
Made it out to work on the transducer today. Sure enough it was bone dry. Filled it with Antifreeze (pink stuff) and checked the Garmin. BINGO!!! Showing depth now. There is NO O'ring sealing the cap on the transducer and had to use a Phillips bit (Ph#1) and my fingers to get the screws loosened for the cap. Kind of a PIA to work on. Didn't show any leakage out from under the transducer after filling the cup but will check that aspect tomorrow. Appreciate the support info to get me this far. 🙂
Hi Jared, would you be so kind to tell me the model of transducer used in the 2021 R29 CB LE? Thanks in advance. Carl
