21ec access overhead lights for bulb replacement?
lproulx
C-24 C SE
Red Owl
How to you get at the bulbs in the 21ec overhead lights? The gold bezels don't seem to want to pry off. Hopefully you don't have to remove the whole 8 inch wide piece the lights are mounted on. I want to replace the incandescent bulbs with LED's.
If you turn the brass outer ring 45 to 90 degrees counter clock wise as your looking at it, or untill you feel it stop then gently pry off. The first one is always the hardest after that you can see how they are attached. Good luck Bob
