Pilotnavigator
- Sep 23, 2014
- C-24 C SE
- FMLT2123K415
- Wanderer
Hi all, I expect a new 2015 21EC to arrive early next year. I have a few mods that will make it ideal for my wife and I to continue crusing the North Channel of Lake Huron. We have been sailing the area for 4-5 weeks each summer on a Sun Cat so we know how to travel in a small boat. My first question is about power. I need some details from experienced 21ec cruisers on batteries. I suspect that the one house battery is not going to work if I expect to stay at anchor for a few days with out running the engine every day. I plan to add two more batteries in the stern port side locker. I plan to replace the two factory batteries with Optima AGM and add two more in the rear. I get conflicting info on if the two in the engine box and the two additional have to be of the same size. As only 2 D34M will fit in engine box I would like to put two D27M's in the rear. If not then I will put in two D34M and live with the smaller size. So what is you recommendation on wiring up the batteries. What should be changed? Battery switches? Alternator charging? External charger? We typically stay out 7-10 days before we hit a marina to resupply and connect to shore power. I have asked the factory to install all LED lights so while at anchor the only power draw will be the fridge and occational use of the VHF.
PS the boat will be called "Wanderer"
Thanks for your help!
John
John
