Shaun
- Nov 25, 2008
- C-24 C SE
- FMLT2120D606
- Rub N Tug
My diver just informed me that it seem as though something might be missing from the end of my prop shaft. From the aft face of the center of the prop is a washer that sits in between the prop and the nut. this washer is not tight and can move around a bit. There is about the same amount of extra room between the prop and nut as the washer is thick. He seems to think something broke or has changed in the last month. So my question is, (1) What parts should be seen on the shaft aft of the prop? (2) If something is missing where is the best place to order it? (3) Can you give me a quick run down on how to change it? Thanks for the any help you come up with.
