25sc - Moisture in storage area under dinette
chapman7132
C-26
FMLR2526A616
Scarlot
Hi,
All along the edge of the flooring in the storage area and under the dinette table we are getting moisture accumulation. It’s along the outside edge of the floor soaking into the material that lines the inside of the hull. That white material has become discoloured near the floor due to the moisture. I have crawled under and it looks clean and dry up where the furnace is located.
Anyone seen this before?
Randy
We had a similar issue on our R27 Classic. Turned out to be from the external light fixture on the outside of the cabin. Had to be removed and re-bedded.
Thanks Michael and Susan! You are referring to the navigation lights? Randy
I believe he was referring to the small deck lights near the side walkways. You have to pop off the bezel with a utility knife blade slipped behind it or a thin spackle knife. Once you pop off the bezel there are two screws.
