25SC swim platform size
Mr Ben
C-26
Lone Ranger
So I am looking to put raptor deck foam on my swim platform. I have it in the cockpit and really like the stuff. Raptor deck does not have a pattern for the 2016 25 SC. They do have some other models. Are all swim platforms the same? I'm guessing the 27 would be. Most likely the 29 and up would be different width. Did they change year to year?
The Inboard R25SC and the Inboard R27 have the same swim platform. Things change when you go to other models (although I am not sure if the Cutwater 26 and 28 are different because they too have 8' 6" beams and could be the same). The only issue would be if you have the rails on the platform. At one time they were optional and then became standard. When I added Sea Deck to our R25SC I made patterns for the company and they made the shapes and sizes of the material I requested. If the company you are using does not have the pattern in stock, they should still be able to make what you want from a pattern.
I do have the rails had not thought of that. I could make the patterns. It would be easier if they already had them. Raptor deck was the supplier for RT. Thats why I was hoping if I ask here on the factory support section they could give me an answer. She also wondered if the swim platform for the 25 classic was the same as the 25SC. They have a pattern for the 25 classic. When I did this a couple years ago I had them make some pieces for the cabin as well. I made those patterns.
Hi there Mr. Ben,
I believe, but am not 100% sure, that we discontinued the R25SC before we started dealing with Raptor. The best way to see if Raptor has the pattern for your R25 would be to check with them directly. You can call them at (707) 278 6749. They're located in Seattle. If they do not have the pattern for your boat, they can help you get one made. Hope this helps.
Cheers,
Ralf
