BB marine
- Feb 1, 2016
- C-26
- Non-Fluid Motion Model
- Grady White 208
- PORT-A-GEE
I now have 145 hrs on our 2016 Cutwater 26. I have never adjusted the packing gland. There has always been a small amount of water in the bilge area under the shaft /packing gland area so I've always assumed the packing was dripping. If we get a heavy rain the water level will go up a small amount and I use my dinghies hand pump to pump it down and also pump the water out that is lying on each side of the tunnel at stern. We started our first segment of the Loop last week cruising 160 miles, 18 hr engine hours. When I was checking the engine, oil, belts...... I looked to see how much water we had taken on to see if it is time for a packing adjustment. The bilge was dry ! What ever water was in the bilge when we started was gone. Assuming it had evaporated from the heat in the compartment while running. I realize 2 to 3 drips a minute isn't much so it could be evaporating. I started the engine to see if it was dripping and didn't see any drips. I haven't opened the hatch while cruising to see. This particular packing gland I have never adjusted, I also don't want to loosen a gland that has been set for 145 hrs to get it to leak. I assume the water cool aspect of the gland is to cool the packing and also lubricate the cutlass bearing while underway, because of the type of shaft log the boat has. I pulled the boat a week before we left and inspected rudder, prop, shaft and cutlass bearing all looking like new. While I like having a dry bilge I don't want to score a shaft or burn up the packing because the packing gland adjustment is to tight. I also think if the adjustment was/is to tight the damage is done and I should be having issues which I'm not so far. I'm not well versed with this type of water cooled gland, I don't know what type of packing material is used so is this common to have a non dripping gland after 145hrs and should I have any concerns? Or should I be happy I have a good working packing gland?
Brian Brown
26 Cutwater
PORT-A-GEE
Brian Brown
26 Cutwater
PORT-A-GEE
