29 (old model) Parasitic electrical loads
R Baker
I'm sure all understand there are a number of continual draws on the battery. So far I've identified the following and what I do to eliminate them overnight.
1. Fridge - I leave it running
2. TV - unplug power cord
3. TV - antenna - left it plugged in as it is awkward to access
4. Inverter - turn to off
5. GPS antenna - Garmin told me it might be continually active and could have a separate power switch ???
6. Other ?.. Please add to the list
The FUSION or other brand stereo...uses some juice to keep memory alive when turned 'off.'
SOME bilge pumps have a float switch which checks 2-3 times/min; This is NOT how the Johnson Ultima switch works which is what Ranger installed on my 21EC. Just FYI.
dave
Water tank meter
Depth sounder
It is frustrating that everything is not run through a single breaker panel. That fuse block accessed via the door in the v-berth is idiocy.
