knotflying
- Jul 25, 2010
- C-28
- FMLT2731J011
- Non-Fluid Motion Model
I had a warning alarm go off 3 times for the same problem and just wanted to let others no of this issue. The alarm itself is of no use because all it says on the read out is "check engine". When I was at Mac Boring getting my heater hoses replaced they put their computer on the engine and discovered that it was the hose that got disconnected from the waste gate. It has happened 3 times since and at least now I know what it is. The simple fix is to just reconnect the hose. This is located near where the air filter enters the intake and of course it is underneath everything so you kind of have to feel your way through it. The problem is twofold the tube (1/4 inch in size) has a very small barb to catch the hose, plus the clamp is one of those squeeze on clamps. The next time this happens I may put a little gasket shellack on the tube and use a screw clamp and tighten the hell out of it. Anyone else having this issue?
