mfreeman_1998
- Aug 31, 2020
- C-28
- FMLT2716I112
Our trusty 2012 RT-27, with 1700 engine hours, recently successfully carried us 7400 miles on the Great Loop. Since returning, I've been giving the vessel a good inspection to identify those parts or systems that require repair, replacement or upgrade. In the course of the inspections I found significant stress fractures in the two brackets, on the front of the Yanmar 4BY2 diesel engine, which support the front of the sheet metal dress covers which protect the top of the engine.
The brackets were removed, repaired and replaced. I also installed new vibration isolators.
I did a quick write up of this project, including pictures, so that you can see what I encountered in case you would like to inspect your motor for a similar problem.
The write up can be found at:
http://www.sonic.net/~mfreeman/RangerTug/Brackets.pdf
