captstu
- Nov 10, 2014
- C-248 C
- Shearwater IV (SOLD)
We had kind of a breakthrough on finding and fixing the over heat problems with my 4BY2.
So far, the heat exchanger has been rebuilt, the exhaust manifold thermostat has been removed and found to be frozen shut, the “O” rings in the fitting that join the exhaust manifold to the water return line have been replaced - we have found a number of warn gaskets. Temporarily there is no thermostat on the boat.
The lines to the hot water heater and cabin have been removed and plugged.
Today, for the first time, we had two people on board so we could look for the suspect leak at 3000+ RPM.
The observer noted that as the RPM rose, the water flowing thru the sea chest STOPPED suddenly. We believe this indicates an air leak into the raw water inlet or a failed raw water pump - the impeller is new since the problem started and the old one had only a small portion of a single blade missing. I back flushed both the transmission oil cooler and the air exchange cooler to remove any potential impeller parts.
So, we went looking at the line from the sea chest to the wash down pump and flush fitting. The mechanic found a failed hose clamp - the 4th we have found since I owned the boat - and also found the inlet fitting to the wash down pump was partially pulled out of the pump. Clearly either of these could have caused the air leak we were seeing.
So, the mechanic removed the hose from the sea chest to the wash down pump. He also removed the flush fitting from that hose and connected the hose bib fitting directly to the sea chest. Tomorrow, I will remove the hose bib from the sea chest and replace it with a bronze plug - just to be sure.
The overheat problem did not go away.
The boat was bottom painted in May and the problem started 2 weeks later. After the problem started, I replaced the raw water impeller — but did not replace the raw water pump impeller gasket - a new one is now on order.
There is some minimal bottom growth that I will scrub off tomorrow.
Any idea where else I can look for the air leak?
