6 months Zinc wear in Puget sound example
Cutwater28GG
seattle
Cutwater 28
Living The Dream
Just thought Id share the results of my latest Zinc replacement with a diver.
I use double J diving. who are great. highly recommend https://www.doublejdiving.com/
they provide a solid set of photos of the work and state of the hull
more photos are here:
https://1drv.ms/f/s!Auy2KJTFDgidjuwWNM0qjqKek6YIXQ
y4m5R2oPxlivfAG5fcSrc266A7swjW7RSj0ITem-ttsdAO8ZORuYnBz6tS08SP1yWjw0PI0zamUcI55gv2EGK4VGm0MgtitTSMRRv3GB-J0DL0g-uhE_rK3AzHtE2Ek69uThwCcVhhQO_A03K14RrapHXuYfm_WUebrmdIbMMQljOIvEZzCEi0GOoaQuwy71WC7XoJLTvN6SlPkBV_O0UK2Bw
y4msGiOWup3zukZrXQKOKFtJHkKfTtJiWm5pIGGdlAtgWqmb92G8YnB1xorhEMpMiaiXJxlE3bqUCuYHuwnhEkm-Y8EitfbLEIBydhuOsTGkKheKwWLrGHLF8fXuvgTPE3jlmz-LR7zurSfR-JhrAmoRmXLx1UKp0bq_C9X8D7GsCi7S_dzHp6XEhJD9QvzxAPnV3WFsO_usPaiQnVrB-4b7A
y4mRNFRI6wQR24l3g44LY7wzxsQlzGklYHWOeOchChmOMa5A2taFChZCI88VvLs3xXplQXoii46C1LQlbfH_hpHN4zFRqhFFnxFb0zKAgJ01rP_jS4isWQJtzrW1Nqwr-4U1TJ_7gwcdw9yu1fyDI3U_Vf3ujTA2WYuxKNAjobJWwP0gJyImhoam1FAW-zVB3E0NDgiz09gi6p5Tjinv-w3ug
y4mrIdNRgR7IyhFCBYqU8xJAf9-fvXXNqgDQg-nEaHAsSYdqxqINrmt9452lXMXNbQzxyN3MlbZMkpjjcjChTaUWXpjK3QUFUe2iYe46mcrTO6wjCILwxT75Mewy0REuldEAEHaT57rQJQJhVAcZOx-elIbZ5foFgescMdAWbbSNg95F-fnNuyz0Uv_Q-CrGd5tIgDIffbFyQVbv4o0MW0umg
Do you have this service performed semi-annually on a routine basis? What does the service cost each time, if you don’t mind sharing. And where is this dive service located on the sound?
Thank you
I found my zincs wearing off while the boat was on the trailer stored away from water even after washing off. There is something in the air too or perhaps I did not wash off thoroughly enough. I found corroded Zink debris in the thruster tunnels and on the ground under the prop. See my album for pics
i was charged $336. i usually go about 4-6 months between zinc changes.
I also have a large divers dream plate on the stern which catches any excessive individual zinc wear around the stern of the boat. this gets eaten very slowly as its so large. about 5% per 6 months.
double J comes to my slip in Elliot bay marina.
