800 mile towing story
Bel Canto
We towed Splash, a Cutwater 30 from Newport OR to Anacortes WA, for the rendezvous. I did my best to make sure we were safe and legal. I had all permits in hand. The tow vehicle was a 2012 Ram 3500 SRW.
20 miles into our trip, we were pulled over by a Lincoln County deputy. After 45 minutes, all he could find was a mirror violation. I also think he is wrong about the violation and will fight it, even if it means flying back from TX. I believe we were in compliance with the rules of the permit. Most of the trip up was uneventful, white knuckle at first, relaxing farther down the road. It takes us 3-4 hours just to get to I5, lots of stoplights and small towns to get through.
Our biggest issues were finding places for restroom breaks. (No rest areas in small towns.) Luckily, I had already converted our head to fresh water and it was usable. The book "Next Exit" was invaluable (except through these small towns). Fuel stops marked as RV friendly seemed to work.
We made a small error heading into Anacortes, as we had programmed Anacortes Marine, not Marina into the GPS.
The red perimeter flags, as well as one Wide Load flag shredded pretty severely. Who knew you could fix flags with 4200? Corner flags were also beating the paint on the truck a little. I will work on that. I understand you can put a license plate over a wide load banner, so next time it will ride on the truck, not the boat. (Just checked that, it would cover the transmission cooler.)The one on the back of the dinghy did fine.
Launched and retrieved on the sling. Pretty easy.
Rendezvous was good, but another story that others will do better than I would.
The trip back was OK, but I had forgotten to empty the water lift muffler. Done at a rest area, the bilge pumps squirting down the road. I also have no idea how the keel drain plug works. My 12 inch wrench didn't budge it. Also, what is the roll pin for, on the plug?
My wireless back-up camera didn't work. The 130 foot advertised range was insufficient. I may play with that some more later. It mounted to the solar panel with double stick tape and it had a great view over the dinghy. Great in theory, not so good in practice.
We were nervous coming back into Lincoln County, as we were told that we would be ticketed, no matter how careful we were, as evidenced when we left. There are some narrow areas and it didn't help when a car swerved pretty far into our lane from the opposite direction.
We got into Newport without incident, then found someone in our storage space. I circled looking for a new spot, when I clipped a trailer. Our boat probably has no damage, except to pride. It is mostly plastic from the trailer that will rub off. The other guy lost about six inches of trim. The moral of the story, never let your guard down. We thought we were home and free.
8.2 MPG on a 2012 Ram 3500 Mega cab. Brakes worked great. Mirrors good enough for easy lane changes.
Other questions will come on different posts.
Almost forgot. Newport Oregon to San Antonio Texas in a couple of weeks, 1800 miles. If all is good, on to Florida.
Thank you for the report. Glad you made it back safely (except for the pride issue). 🙂 We trailered from Port Orchard to Anacortes and home again. That was the first long-distance trailering since we purchased SLO Ranger in November of 2012 and brought her home from Sacramento.
I feel much better about trailering after that experience.
Joe
We just completed a round trip from Belton TX to Anacortes WA towing a 26 ft Cutwater with a Ford 250 diesel 4X4 - 4,888 miles requiring 112 hours driving using 395 gal diesel and averaging 12.4 mpg. Would strongly recommend a trailer tire temperature and pressure monitoring kit with in-cab display. Ours was installed by Discount Tire. We cut a tire driving from Wyoming to Colorado and the TPMS notified us by audible alarm when the pressure dropped from 80 to 65 psi. We were able to reduce speed, look up the nearest Les Schwab Tire dealer, and hobble in at 4:55 PM. They replaced the tire and had us back on the road in 15 min. Saved the day - Bill
I don't even have one for the truck. Dodge assumes that all 3500 are duallys and can't install them. Us singles could use the OEM tire monitors, but they aren't even an option from the factory. I would need monitors for 10 wheels.
Thanks... I'm glad you made it up and back home safely.
My first trailering experience was also completed with the Roche Harbour Rendezvous. We trailered our new R-21EC from Edmonds to Skyline/Anacortes and back, a distance of around 150 miles round trip. Our 2012 Volvo XC70 T6 with Polestar proved to be capable for this task.
The most challenging task was in fact backing up the boat+trailer into our circular driveway. Our road is quite narrow and my neighbor across the road from us has a long hedge near to the edge of the road. This made it kind of awkward to get enough road space to angle our boat back into the drive way.
I found braking was very controllable and I have to believe the EZ-Loader hydraulic surge brakes were helping me a lot. I'm very impressed with our EZ-Loader trailer and the extra LED lighting that Ranger installs on the boat and trailer.
Thanks for the trailering reports all! Such info is very interesting to me since - if I had my way - we would eventually be doing a heck of a lot more of it as we followed the warm weather in a migrant manner. The reality for now though is that we are stuck here for now as the nice weather becomes less and less and the boat will be put away soon until ~ May, 2016 (that darn work thing!).
We upgraded this past summer from a 2007 F-150 pulling our former C-Dory Venture 23' (which probably is < 6,500K lbs inc. trailer) to our current 2011 Ranger R-27 on a triple axle trailer (somewhere in the 10-12K lb. range now) which we now pull w/ our new 2015 RAM 2500 diesel truck.
The first pull was bringing the boat up from Portland, OR area back in early July to our home in Quilcene, WA a trip of only about 200 miles. Wound up getting some real scary high temps (~ 205F) on some of the hubs on the used, but new-to-me trailer but I made it. Subsequently, pulled the boat and trailer from our home to Port Townsend which is only another 30 miles. Have since had some work done on the trailer so hopefully the hot temps on the hubs will be corrected for now.
For Bel Canto..... you mentioned the following sir:
Just to clarify, how did you determine "Fuel stops marked as RV friendly...."? Is that from the book "Next Exit" or some kind of other travel and/or trailering guide?
Dan, Tanya, and Hannah on Echo
We have been using the "Next Exit" guide for years. It shows "big rig friendly" parking and fuel access in RED in the book. Easy!
Thanks for clarifying that Jim.
Afraid I was not familiar w/ that guide book but - having run into lots of tight gas stations or other non-trailer friendly situations - its good to know such a book exists.
Thanks again sir.
Take care,
Ditto on Next Exit book. Look for the red. My wife felt a little under the weather on the trip out and she easily found a Walmart in the book with RV friendly access. No more seeing the store after passing the exit.I will look into the tire monitoring.
I see you met our sheriff's department in Lincoln county. There are numerous entries in the local fishing blog about this situation as well as complaints to the local authorities about what has been called harassment. There are rumors that this policy relates to a fatality in the recent past affecting some of the locals. You haven't been singled out. This is almost policy for the ports in and around Lincoln County Oregon.
