LADYBUG TOO
- Dec 9, 2010
- C-288 C
- FMLT2916B909
- LADYBUG, TOO
I have been told that Ladybug, Too is the sixth R-29 constructed. How can I access the A/C control panel on the unit. There are three fuses on the circuit board shown by Marvair. The A/C panels came up after my lightning strike and then I heard a fuse blowing when the A/C circulation pump went to ground. The pump is ok and I did a test run by direct connecting it at the factory splice. The insulation was burned on the hot and ground so the splice had to be repaired. I am thinking that that ground fault took out one or more of the fuses on the A/C unit.
Pat, Ladybug, Too
Pat, Ladybug, Too
