mmcdonald47
- Mar 2, 2011
- C-26
- fmlr2517d112
- Walk-In-The-Water
My A/C keeps going to HPF and stopping. I clean my strainer monthly and back flush all the lines. Normally this alleviates the problem. However, this time it is not correcting. I have water flow all the way thru the pump but when I turn on the A/C i cannot feel the pump kick in. Not sure if there is flow thru the pump that this implies that the pump is primed. If not how do I correctly prime the pump. I always open the seacock with the filter off to verify that there is good flow. No problems there. On the discharge side of the pump water comes out but it doesn't appear to be by pressure.
Cannot find where the relay is for this pump or even trace the wire. Has anyone have any ideas as it is not on my schematics.
Mike McDonald
Walk-In The-Water
Mike McDonald
Walk-In The-Water
