Hensch42
- Oct 2, 2024
- R-27 (Outboard)
- FML2722H324
- LEONCITO
2024 R27 OBLE - Wabasto unit Have docked @ several marinas withe same result.
Running the A/C while cooling, the humidity is brought down as expected, but during off cycles, the fans continues to run and humidity increases to around 80% . Then after some time, the a/c activates and humidity goes down. Upon awakening, the humidity readings are in the 80’s.. used the Humidity setting & didn’t notice much of an improvement, maybe didn’t run it long enough. At least I have not noticed any accumulation of moisture. I keep a dehumidifier on board while at home port or in storage.
Just wondering if any one else has had this experience and how they’ve handled it it..
