Abso Sinewave Inverter Charger Problem
Sea Leggs
C-30 S
FMLT2935E818
Black Crab
Hello, I have a 2018 RT 29S and came home from a cruise and the Inverter seemed to be malfunctioning.
Here are my symptoms which I had.
When no shore power, there is no AC on my panel. All breakers are showing no power and the green LEDs are not lit.
When shore power is connected, the main breaker LED is green but no AC voltage is showing on the meter. Every few seconds there is a pulse of AC on the meter but doesn’t stay. The breakers on the left side (outlets, Microwave etc) are all showing no power. The accessories breakers in the middle are showing power(LED Green)
The Remote Display has an Amber flashing status light and the Display light is green. The screen shows DC voltage.
The Inverter fans are not running.
This morning I cycled the power by turning off the battery switches and disconnecting the shore power. I then turned on the battery switches and connected the shore power and everything came up.
So the final status is: With Shore Power connected all breakers have power with a green LED and the remote display shows FUL. The meter shows 120V AC.
When I disconnect the shore power and run the boat I get the left side of the panel with the outlets, microwave showing power with the green LEDS. No power showing on the middle panel Accessories or on the Main AC Breaker and 120V AC on the meter display. The remote display shows a voltage 13.9 etc.
Is this the way it should show in each of the states. Shore power or no Shore power?
Rick
778-679-1183
