Skeeter
- Jan 23, 2017
- C-28
- Peggy O'
After a hull/boat survey. The issue was whether the Inverter for the Solar Panel should be isolated to low AC appliances. The surveyor said that all appliances are linked to the inverter. My understanding is that the Solar Panel should be able to run the fridge when under power, however, the microwave is on this same circuit which would draw more amps then the inverter could supply. What is the recommendation as to what you can or can not power with the solar panel and what should be turned off while underway.
