AC locations on 2022 R 31
Shabuba
R-31 CB
FMLT3110I122
Shabuba
Will someone inform me as to the location of the AC which serves the main cabin of a 2022 R-31?
Mine is a 2013... probably similar.
Within the Cave... go to the end (towards the bow). You will see an easily removable, small carpeted hatch plate that is attached via Velcro. Remove it, shine your flashlight inside and viola - the Main Cabin air-conditioner/heater.
If you need to access the air con unit, remove the entire vertical panel - the one that holds the small carpeted hatch plat. It is very simple to remove, there are several screws around the edges of the vertical panel. When you remove the panel there is enough access to work on the unit.
Thanks. Task completed.
