AC Panel Accessory Switches
Bosn Mate
R-29 S
FMLT2912I718
Tingira
I have a number of accessory switches that light up when turned on but don’t seem to be hooked up to anything.
Can I assume there is power to the switches but nothing beyond that? I want to add an additional gfci outlet and use an accessory switch if available.
Thanks!
That is the case on my c-30. There’s an entire bank of 120V accessory switches that aren’t connected to anything.
My R-23 had one unused switch on the 120V panel. I used that for my second charger. Very easy hookup.
My RT27-OB had 3 unused breakers on the 120volt AC panel. Check the amp ratings on those breakers before using them.
If I remember correctly on mine, two were 15 amp and one was a 10amp. I know all three weren't the same.
I used one of the 15amp 120volt AC accessory breakers to connect to my 2nd battery charger that I put in for my LFP house bank.
Here's what the back of my 120volt AC panel looked like. The accessory switches on the bottom of the pic were unused/available for use.
https://www.letsgochannelsurfing.co...kxdnj0k3-52ad1e12-cb6e-4cac-b6da-0927cef68ab2
Here's an even better picture that clearly shows two of the breakers were 15amp, the third spare was 10amps.
https://www.letsgochannelsurfing.co...kxdnj0k3-59cbd76c-363a-45b6-b724-7ae89f4cd253
Thanks to all!
