Happy Place
- Mar 16, 2021
- C-302 SC
- Happy Place
2014 R31 CB ....I'm having a problem with my generator. I start up, switch to generator on the AC panel. The analog dial on the AC panel shows that on 1 I'm am putting out 120 volts but when I switch to 2 it shows zero.
AC 1 and 2 light up when I switch them on, as do the switches for the air con relay, air con fore and aft...and accessory however ....none of the other switches will light up it operate. So no power to the wall sockets, water heater, etc....
Also....when I switch on the charge switch, the green light dies not come on....not sure if I'm even charging. The yellow charging light on the inverter also does not come on.
I've checked every fuse and switch I can think of to no avail.
Can anyone help?
Can anyone help?
