Patuxent Bob
- Aug 20, 2023
- R-43 CB
- FMLT4302H223
- DAZZLE
My R43 no longer has Shore power on the Shore panel 1 electrical panel. There is power on Shore panel 2.
The Inverter shows a status light of amber. There is an inverter message of EO1, which is that the house battery is low on charge. The charger has been running and the panel reading for the house battery is 100% charged.
When I try to test an outlet using the house battery power via the inverter, I will get power for 2-5 seconds and then the power shuts off.
When the inverter is turned off at either the inverter control panel or the inverter control switch, there is no difference. There is no AC shore power, even with the inverter off.
Is there a fuse or breaker for that side of the panel? If so, where should I look? What other considerations are there?
Bob
Bob
