AC WIRING SCHEMATIC
etcwade
FMLT2711D011
CHUBASCO (2011)
Are there any AC wiring schematics out there. I looking for one that will show me the hook between the shore power connection and inverter/charger to the AC panel. It is for a 2011 R-27. Thanks for the help.
Gary
Gary:
I have my R-27 Owner's Manual that has wiring schematics in it that may show what you're looking for. Not sure how to get a photo of it onto the forum however I could email you a copy. Why don't you PM me with you email address and I'll then send what I have off to you.
Jim F
Gary
The 27 manual with wiring diagrams is available on the forum, look under Ranger Factory tech bulletins, then you will see the R27 manual.
Gary,
Not sure which inverter you have, but there should be a wiring diagram in the inverter material showing you the hookup. Basically there is power in from shore power and then there is power out to the panel. There are also connections on the inverter that go to the batteries and an inverter switch (on/off) in the battery compartment. This switch has to be on for the batteries to charge when on shore power. Don't ask how I know that! It also has to be on if you want to use the batteries for a/c through the inverter.
Hopefully this helps.
