dbsea":3r263l8s said:
Nwdiver":3r263l8s said:
May ask why you are adding a generator? I’m considering adding an EFOY Pro 2800BT Fuel cell, it’s around 10K and the installation seems easier and much lighter and quieter.
Great question. Longer cruising trips where we'll be away from a dock for weeks at a time, and I had also considered the possibility of a water maker. The EFOY Pro is certainly interesting - but I was having a hard time understanding the power output in comparison to a genset. It seems like the 2800 only puts out 105-125 watts, and the max charging current 11.9A, whereas a 5.5kw genset can put out 45 continous amps and 5,500 watts. It seems like it would take an eternity to charge batteries on the EFOY, am I understanding it wrong?
Your understanding is correct, the difference is how you use them. The generator you use to quickly charge up your batteries, the fuel cell you leave on for longer(24X7) and hopefully keep up with your usage. In order to determine what fits your needs, you need to know what your total energy needs per day.
I don’t really have too many heavy loads that run continuously, so the Efoy, along with solar, should be able to catch up relatively easily. If I fall behind on charging, I can always run the engines
It’s all down to how you use the boat, if you have air conditioning, a generator is probably better. Not sure how much power a water maker consumes, but that might push you over to the generator as well
