Hi.
I hope these are 2 simple questions. I recently moved my C-28 out of a marina where it was connected to shore power onto a mooring. I now seem to be regularly in trouble with insufficient power in the house bank.
1. I am thinking about adding another battery to the house bank to bring it up to about 300aH. My question is this: the wiring to the battery terminals is really tight and won't extend to reach a third battery, so can I just add the 3rd in parallel and leave the original wiring alone, or will I need to replace the wiring (either +ve or -ve leads) so that they connect at battery 1 and battery 3.
I found a site which said, "you CAN connect your load to ONE of the batteries, and it will drain both equally. However, the preferred method for keeping the batteries equalized is to connect to the positive at one end of the battery pack, and the negative at the other end of the pack …" but it is the internet so you never know if it is good advice.
2. My second question is about the solar panel. The meter in the cave tells me I am only ever getting abut .13 amps out of the 140w panel which strikes me as way too low. Other posts on Tugnuts say people get about 6 amps and sometimes more. I keep the panel clean, and I have read about shifting it away from the radar shadow, but is there likely to be some other cause? Previously, I had put this low output down to the batteries being fully charged but I wonder if there might not be some other well-known problem?
Thanks for the any suggestions.
GraemeC
GraemeC
