Gypsy
- Jan 16, 2021
- R-21 EC
- USFMLC2804F
- Gypsy
Just finished installing Starlink internet (permanent installation) on my boat. So far, it is working very well. Here is what I did:
1) Bought the Starlink Roam Dishy.
2) Cut the unit apart, which voids your warranty. That is the tricky part. You have to cut all around the perimeter of the dish, 3/4" above the face of the unit. You have to be very careful not to cut into the circuit board which is 1/4" below the cut you are making. You save the piece with the circuit board and throw away the rest of the unit which includes the control motors, and mounting pole.
3) Buy a new case for the circuit board assembly. You get the case from Star-Mount. The case measures about 13" x 22" x 1" thick. Star-Mount provides detailed instructions on how to do everything.
4) Mount the new unit on top of the boat (flat). Run the connecting wire down into the boat and plug into the modem. Snaking the wire so as not to be seen is the hard part. You have to dismantle several panels. I routed mine down into the cave.
5) I also installed a push button power switch so I can turn the unit on and off easily.
Starlink allows you to turn their service on and of on a monthly basis. So during the boating season you turn it on and in the off season turn it off.
star-mountsystems.com shows detailed instructions. You tube also has several videos.
The total system isn't cheep (just under $1000) but if you want good internet, give it some thought.
