knotflying
- Jul 25, 2010
- C-28
- FMLT2731J011
- Non-Fluid Motion Model
My engine just quit today. Within minutes I had the problem solved thanks to a conversation I had with Fred Volkwein of the Alice J. He advised me back in June that his engine quit and it was the fuel pump relay that burned out. I purchased a spare and had one when needed. I purchased it at NAPA it is a bmw part made by tyco - 23134‑k59‑x313.
I am suspecting that the failure is related to vibration, but can't confirm that yet. The relay is located in the ECU box and is blue colored and 3rd one counting from left to right when you are looking at the box and facing starboard.
The clip that holds the relay assembly had partially failed and hence this relay was vibrating significantly more that the others. I have epoxied the clip back together and will be making provisions to help reduce vibration to these relays. For the life of me I cannot figure out why Yanmar decided to put such a sensitive component attached to a vibrating diesel engine. It has isolators between the ECU and mounting plate, but there is still considerable vibration. Keep in mind that this is the same plate that the fuel pump clamp is mounted to.
