aft refer 27ob
sfladgard
Silverdale, WA
Exhale
Purchased used 2020 rb27ob, adding aft refer. wiring diagram shows orange hot lead from fuse box, verified. Where does this terminate?
My R27-OB came with the cockpit refer installed. I would bet that the wire has to go from the 12volt DC fuse block located in the cave behind the small wood velcroed door, it would go down, and towards port, under the doorway, there's a passage way there that leads all the way under to where the stove is. From there, you can go aft into the port lazarette, which the cockpit refer is right above.
The fuse for the cockpit refer in the fuse block is right next to the cabin refer.
I have the cockpit refer installed by the factory.
This is a picture of the fuse block it terminates in. The cabin and cockpit refer's fuses are right next to each other in the same fuse block.
https://www.letsgochannelsurfing.co...kxdnj0k3-57e8f1ca-8fcb-4ffc-ab2a-5b5957c0e8e5
This is the cable run to get from the fuse block on starboard, over to port, where you would go straight aft and come up under the cockpit refer.
https://www.letsgochannelsurfing.co...kxdnj0k3-0f0402fb-b27b-442f-86a5-c1afe9e707b9
Thanks Martin
Turns out that the factory ran the pos and neg and clearly labeled them along with proper heat shrink crimp connectors in place. Hard to see until you remove the shelf so you can stick your head in there...
1
