Cutwater28GG
- Jan 14, 2016
- seattle
- C-28
- Non-Fluid Motion Model
- Cutwater 28
- Living The Dream
My boat has the AGM factory option which has since been replaced with the same model universal AGM batteries. To my knowledge this means the charging circuit should only be putting in about 14.2 volts into the batteries to charge - less than with regular wet cell 12 volt batteries. which is happy with the higher 14.6
Today however I finished the install of a new smartgauge and noticed I have a 14.6 volts charging rate which is too high for AGM's causing a over volt error on the smartgauge. (it made me realize the error as its hard to see the difference between 14.2 vs 14.6 on the blue seas analog panel - and I never noticed!)
question. are the universal AGM's actually real AGM's with the required lower charging rate or are they the "fake" AGMs which are wet cell batteries with a glass mat but no additional special chemicals which require the lower volts?
I ask, as the smartgauge manual in the battery selection menu talks about two different types of AGM's.
I'm confused as I'm pretty sure the solar charger is set to AGM's and I thought the promariner charger was set to charge AGM's with the lower rates. seeing 14.6 volts is concerning as im probably killing the AGM's prematurely at this rate.
Im going to have another look at the promariner tomorrow but keen for other ideas
