I am entering the 6th year for my 6 AGM batteries. How long have others had acceptable service from their AGM's ? I know that responses may wax how well you have done this or that, but... the boats electrical systems are not designed to properly look after AGM batteries.
AGM (Deka / Penn) require a charge voltage of 14.4 V and are very sensitive to this voltage to ensure long life. The Promariner can be adjusted to provide 14.4; my solar panel provides normally about 13.9, but varies depending on the solar intensity; the alternator is set at 13.9 or 14.1 (mine seems to vary). There are means to equalize the batteries either with the Promariner or by the Solar panel which goes thru an equalizing cycle every 28 days. The Deka / Penn battery site has considerable info on these batteries.
All in all, the life of these expensive batteries is compromised by the installed charging systems, primarily the alternator output. It seems to me that since Ranger offers AGM's as an upgrade, they should include an upgrade to the voltage regulator to provide the required AGM voltage.
So, how many seasons have you run AGM's ?
