plewis
- Aug 12, 2016
- C-288 C
- Last Chance
Hi All - The pan under the cabin air conditioner is leaking a trivial amount of what I assume to be condensation into the cave. After pulling off the mouse fur panel I see the leak is from a pipe-threaded hole in the pan that is plugged, labeled DRAIN. Does anyone know what the intended use of this drain hole is, so I can determine how to fix the leak - (a) add a nipple and hose to drain the water to the bilge, or (b) fix the leaky plug and assume the water in the pan will evaporate before spilling out. Any ideas or experiences?
