Gin
- Dec 12, 2012
- R-31 S
- Echo II (2019)
I've read through as many of the AIS threads on the forum as I can find. I've researched a lot of different AIS brands and options. I have narrowed the field to the Garmin 600 and the Vesper XB-8000. The Vesper ends up costing a bit more. But the advantages it offers are filtering (so that you can see only what you want to see and declutter the screen) and wifi (so that you can see not only the AIS info on an iPad or similar mobile device, but also a lot of the other data running through the NMEA 2000 backbone). I'm leaning towards the Vespar . . .
Either way I go, I would love advice from those of you who have self-installed about the following. (Note: I'm installing on a 2013 Ranger Tug 27).
1) Where did you mount the transponder? Inside the box behind the helm station seems the most logical, but real estate there sure is limited.
2) Where did you mount the GPS unit? In particular, how many (if any) of you have tried mounting it internally? The tech folks at Milltech.com (who sure seem to know their stuff) said that GPS antennas work well under fiberglass and they recommend I start by trying to mount it somewhere in the cabin. (Note: the Vesper has an app that permits you to start things up and test the GPS reception while moving the antenna around. That will help with placement.) Just wondering if any of you have tried mounting the GPS receiver internally and, if so, how satisfied you are with that set up.
3) For those of you that mounted the GPS antenna externally, where did you mount it?
4) And related to question #3, how hard was it to bring the cable from the external GPS into the cabin and run the wire to the transponder? What route did you take?
5) Finally, getting to the NMEA 2000 backbone requires pulling the refrigerator, yes? Any tips or tricks on (a) hooking up to the backbone; and (b) pulling and replacing the refrigerator?
If any of you have any other experiences or advice/tips/tricks to share, I welcome it all. This forum is always the best resource (along, of course, with the wonderful folks at the Ranger Tug factory).
Thanks!
- Gini
Thanks!
- Gini
