ALICE J
- Oct 21, 2014
- C-28
- FLM27251011
- ALICE J
- NONEHERES
Since owning my 2011 R27 for 6 years, when I start my 4BY180 the alarm for the engine would sound when I turned the key, as the engine started the alarm would stop. Recently after trailering the boat back from Kentucky, I put the boat into the water. As I started the engine, the alarm sounded, said check engine. (yep the engine was still there!) Stopped the engine and checked the oil, belts, water, all good. Next started the engine had good oil pressure, water flow. I let the engine run for perhaps two minutes, then the alarm stopped. Curiously when I start the engine the alarm momentary stops, then resumes for perhaps two minutes, then shuts off. Where is the alarm sensor, is it in the oil pressure switch? Where else should I check?
