Apparently the Yamaha 300 produces 70 amps. Can anyone confirm the outboard on a 27R charges the house batteries, and if so - how? There are apparently two battery combiners - does one combine starting to house battery (pair), and the second combine to genset/thruster battery?
I have apparently had a dead genset/house battery after dry storage - perhaps due to parasitic draw from the gasoline genset? I am told the Bluesea combiner drops out at 10.8V, so if you fall below, you'll likely never be able to charge. As an aside, my dry storage is with both batteries disconnects OFF, so it's surprising the genset/house would fall so low.
Thanks - Gregg Carlson, 2019 R27
