emtlibby
- Aug 26, 2023
- R-25 (Outboard)
- MaiTai
Hello!
I own a 2021 Ranger R-25OB. I am the second owner having purchased the boat last year.
Since I got the boat there have been a number of what I call "holidays" that I've had to repair/fix:
None of these were a big deal, and I just chocked it up to maybe not awesome quality control.
A few weeks ago, while overnighting with our kids, and running the AC, they woke up totally drenched in water. Turns out the drip pan had overflowed and poured water on them all night. After drying them off and getting their clothes and bedding dry, I took apart everything to inspect the AC. I troubleshot everything, and eventually found that the issue was that the drain hose to the shower sump was connected to a plugged fitting. When the sump is bought from Johnson, it has a few different possible connections. All of them say "CUT HERE", indicating that you need to cut the end off before connecting a hose. It seems the factory connected the drain hose, and never cut. I cut, and repaired it.
As part of the wet bedding was wet overnight, it also stained the mattress covers in the tunnel.
I reached out to Ranger Tugs and explained the situation. I asked for a courtesy replacement of the cover. A low cost item I believed. I guess my theory of the case was that this was not something "breaking" but rather something that was wrong since day 1, but just discovered. I guess I expected as good will, they'd just send me a new cover.
They responded, and told me the boat was not in warranty, and that they could not send me a cover. They said it would take them a while to get a price together, and that I should just find someone local to make a new one. I responded as I said above, explaining that I figured this might be a reasonable good-will replacement based on the circumstances. They stopped responding altogeher, even though I sent a follow up email over a week ago, with still no response.
Feels crappy... Not how I would handle it. I know I'm the second owner, but we were considering upgrading to a new 29 next year, and now I have a bad taste in my mouth. Am I being unreasonable?
- No bilge alarm
- Battery charger mislabled wires causing charging to not work correctly
- Downrigger wiring shorted out because fuses were placed in fuse block, but wires just cut (boat has no downriggers)
- And a few other small items that were just odd, one was my boat having an additional battery that did not appear in any diagrams. Eventually someone at the factory helped me figure out the one off wiring.
