Anchor light indicator at helm
Grubin
Island packet IP40
Does anyone know if the 2022 Ranger 29 has a dashboard indicator light when on? That rocker switch in the Nav Light position has all switches lit, but on my boat there is no way to know if the abchor light is on without looking outside.
In my 2022 R31S, up is anchor and nav lights, center is off, down is anchor light only.
I don't imagine there is any other indicator light other than the switch. That being said, it should be simple to wire one in. I put an indicator light for when my windlass is energized. I use a very small LED and put it in the switch plate attach screw.
I hope that helps!!
Rocky
Tha ms.for the response se.
What I'm wondering is if there is an inictator light on the switch when the.anchor light is on, that is factory installed at the factory as.standard.equipment on a 2022 Ranger 29.
Not on my 2021 R29. Only Nav lights on have an indicator.
Hi all,
Gary S. is right. The switch does not light up in the anchor position.
Cheers,
Ralf
If the switch has two light panels (strips) on the rocker face it is possible to have the lower panel on and upper panel off for anchor-only mode of operation. On my older R27 I had to add an addition connection to the switch to make this so. As best I can recall from 10 years ago I added a jumper from the anchor light terminal of the switch (that is the terminal which has power when the rocker is in the down position) and the terminal for the lower indicator which is on the rocker face.
