Anchor Light Replacement Lens R27OB
Snaumann
TugNut team or Factory,
What is the anchor light lens specification for ordering a replacement? Tried measuring the housing but can’t seem to find a lens that fits.
Thanks!
Scott
If it is the same as 2017 R29, there is one on eBay right now:
Aqua Signal 360 Degree Mast Light Lens Only Series 25 LENS ONLY 83513001
Here is another option for you if you want to go with LED - 30-LED 42mm Cone End Festoon - Mini-Max (FS-42-30C) marinebeam.com
Thank you! Fortunately the bulb survived but the lens housing (outer cover) fell off while cruising. Very happy with Marine Beam products.
If it is the Aqua Signal Boat Masthead Navigation Light 25000-7 | Series 25 12V then the entire unit is in stock at Amazon for about $36. Sold by Great Lakes Skipper which also sells them directly for $25 plus shipping.
