Anchor light
BessieO
C-24 C SE
Bessie O'Donnell
I bought a used 21EC. The wire from the anchor light is snipped just below the light on the mast and I'm wondering how to re-wire it. I don't see an obvious path downing the cabin.
Brian Rooney
It runs down the Stripper pole, if you look in the cabinet under the sink you will see the wire.
There should be a connection on the smoke stack so you don't have to replace the whole wire run!
Hope this helps and good luck. Bob
